1936 rear roll up window drip pan
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Does anyone make a replacement drip pan for the rear roll up window for a 1936 ford five window coupe?
Thanks in advance!!!
not sure if theres one in there, ill have to look at mine. is there such a part. ken ct.
I am installing a roll up window in my five window. It currently has a fixed window. But I know the three window coupe has a drip pan for the roll up window. It has a drain outlet and a hose that I believe routes along the passenger side and exits out the passenger quarter panel area in the floor. I also think there is one for the five window. Correct me if this is totally wrong.
Thank You!
Three & five windows both had rear drip pans with drain on passenger side IF the window rolled down. You can make the pan but you need to get the window mechanism and inside panel that holds the mechanism. Roll window down, add and inch or so, and make pan go to that depth on driver's side and make it an inch DEEPER on the pass side so will drain to side where you attach nipple for 5/8 or 3/4 drain line. I routed mine out the back but was careful to keep the drain line going DOWNHILL. I could measure my pan but top is chopped so window is much shorter. Good luck. Al
<ul>[*]Al's 36 Ford web site[/list]
