Could you explain that a little better?
The 35-40 front spring is a lot narrower (eye to eye) than a 35-40 rear
How do you you modify the 35-36 rear bones to make narrow enough to fit the spring?
TIA
Michael
If memory serves me right,.....
The unsprung eye to eye centers on a stock 32-34 rear spring (as well as 1935/36) is 46-1/2", The same eye to eye dimension on a 1935-40 front spring is 42-1/2" However it has a higher arch, and more of a spring pack,..
Eye to eye is the improper way to measure a spring,... It actually takes into account the Arch along with the center hole to eye dimensions. I cant remember what the proper formula is for figuring this out at the moment. but when I find it, I will post it,....
Unpacked,.... With the main leaf mounted alone, it spans the additional 2" per side fine (because of the higher arch),... then unpack every other leaf,... And repack the spring with the main leaf still mounted to the shackles & spring perch. ( I can post the process that I use for this as well,.. if anybody is interested)
(* I usually mount late model axles with this method,.. and more often than not move the mounting brackets inboard 1 1/2" per side from stock.
But when you do this,.. the front mounting position of the wishbones, the shackle mount barrels being 90 degrees to the rear axle, and of course pinion angle are critically important.... *)
Also, I will try to post better pictures of this set up, and how to do it,... just have to remember to take a camera to the shop when I am doing this,....
This is all stuff I learned form a couple old hot rod guys decades ago,......
