Fortunateson
Not much strength difference between the late32-34 and the 1940. The weak link in most of the banjo rearends is the key way in the axle shaft. The axle and hub should be lapped to get the best fit and check if key slot is in good condition .
Thanks for the info/advice. What about between the Model A/early '32 and the later versions?
