allenmichael
I have Vintage precisions hub puller. have been following procedure ( with exception of using PB blaster rather than acetone and ATF) with no luck. Have backed off adjuster until it stopped (not sure how many clicks they offer up). Heated, hammered then put puller on . Have ony put 130 ft pouds to it as I have seen multiple differences in directions. Some say 125 ft pounds others 145?? In any event after 5 or 6 attempts still no luck. A bit hesitant on the acetone route. using MAP gass to heat up and flame control is a bit large. Heat Looking for any assistance, and specific step by step on the acetone route ie heat first , apply, or apply, then heat etc..
