I have a couple of 1936 Ford Pickup grille shells. One is a complete shell with grille, but it's got some metal damage on the lower portion of the shell. The other appears descent but someone had cut out the grille. I haven't sandblasted but it looks like its had some body work done. Between the pari of them I can end up with a good shell and grille, but I need information on original dimensions across the shell. Attached are measurements on the two shells. Right side is the shell without the grille; Left is the damaged shell with easy repairable grille.
Can anyone provide dimensions that will help me get the grille worked to its correct form? These measurement were taken across the shell at the various bolt attachment locations. Thanks
