AnthonyG
Just hi-lighting a few of the obvious. With no rebuilds or radiator replacement or reconditioning & normal aging with minimal maintenance ur engine & cooling systems are more than likely loaded with rust. Only very occasionally a find with a car having exceptional owners it’s whole life who we’re fastidious about regular frequent flushings & antifreeze changes. With this & your description at the least you need to do a few thing to insure your not gonna be chasing ghosts for another decade!
-Send the radiator out & have all checked & serviced & Probly r-cored.
-As said if heads & radiator are not aluminum a stronger caustic soda flush will loosen a lot
more rust & crud.
-Install hi-flow pumps
-Being a purist is good but to enjoy & drive the expansion tank, a pressure cap & a 4lb release valve on overflow tube will help the tank work.
-As said make sure your timing is correct.
-If all this doesn’t help ( it will) it all needed doing to give you a good base line. But if overheating still exists albeit less & I know this makes purist’s crazy, go with a strong electric fan. On ‘35-‘36 a push fan is easily hidden behind grille in front of radiator. A DIY shroud really helps as well!
If you don’t want to do the Fan, shroud & overflow tank & overheating is still there albeit improved you’ll need to live with it or pull engine & send block out to be hot tanked & professionally cleaned then refresh / rebuild as required.
I’ve been their & chased the ghosts for 5 years & know how frustrating it can be.
JMHO, truly wish you the Best in resolving!
more rust & crud.
