Joeyv
I have a 36 Roadster. When I purchased it The hood was on it and so was the hood ornament. I took the hood and hood ornament off, removed the radiator, and had the radiator re-cored. I did not remove the grill or the grill shell. I’ve tried to put the hood back on and I’m having a difficult time doing it. The radiator still has the upper brackets attached to it like it did before I sent it to the radiator shop. The grill shell still has the tabs attached that the upper radiator bolts to, they haven’t been moved. The only change was the radiator was removed and put back in the same place. The radiator is already leaning as far forward as possible, it is touching the grill shell. I’m having a couple problems. One is the front hood bracket that secures the hood to the top of the radiator doesn’t to line up with the mounting holes without quite a bit I’d effort. The distance from the radiator to the firewall is the same (+/-1/16) on both radiator support rods. The hood margin is too tight to the cowl on one side of the car, and the margin to the cowl is too large on the other side of the car. When the hood is mounted, the inner lip of the hood catches on the mounting bracket on the side of the radiator. The other problem is appears that the hood ornament, when its bottom is slipped into the center trim of the grill, the hood ornament’s mounting holes do not reach the mounting holes on the top of the radiator. It looks as though the radiator would need to move forward or sit lower. Neither seems possible because it is already leaning against the grill shell and it is sitting on the same hardware as when the radiator was removed. I tried putting the hood on the car with the help of a buddy, I think next time there needs to be 3 of us. Any suggestions, or ideas where I may find the process of mounting and aligning the hood documented? Thanks!
