1936 ford trans upgrade
mike37cdn
I have a 36 coupe I need to redo the trans I heard that you can put a newer set of gears in the trans does any body know what years can be put in the trans thanks the car is all stock mike
You are probably talking about the later gears with improved syncronizers. If so, the '39-'48 gears are what you want. I would suggest picking up a copy of Mac Van Pelts transmission book. Will tell you everything you need to know about these early Ford transmission.
Here are some pictures of a transmission I built this past May for a friends '36 fordor touring sedan. Used his '36 case with serial # that matches frame & title, '40 - '48 pass car side loader gears that were in excellent condition, '39 top/tower, '36 shift lever, and '35-'36 rear mount/bearing retainer. Working like a charm in his '36.
I got to drive this '36 at the Gettysburg ENM in June, and felt that it shifts much better than my '35 Avatar fordor that still has its stock transmission. Also, I could not make this '36 jump out of second gear no matter what I did, like my '35 jumps out of second now. Will be making this same gear change on two of my '35's as soon as possible.
I am running a '39 tr4anny in my '35 as I heard the same. Truthfully I didn't notice that much of a difference in the way it shifts.You definitely want to consult Van Pelt prior to any purchases as I know there are differences internally. I.e. the case on the 39 is significantly different and has the shift tower about 2 inches removed from where it was on my '35. Also the shifter is a different configuration both where it goes into the tower and meshs with the forks and it's shape for clearance is different..
