- City
- Annapolis
- State
- MD
- Price
- 2200
[FONT="]SOLD![/FONT]
[FONT="]Completely rebuilt running 1936 Ford LB flathead engine. All 8 cylinders were sleeved with thick wall sleeves and standard bore. New pistons, rings, main, rod and cam bearings, timing gears, valves, guides, springs, retainers, adjustable lifters, oil pump idler gear with shaft, flywheel ring gear, distributor points, cap, rotor, NOS coil, and gasket set, reground camshaft, rebuilt oil pump, flywheel reground. Heads and block were resurfaced. Crank was turned. After assembly, the engine was installed to a project car that is not road worthy, so engine has only been run around garage. Have video. Has 25 psi oil pressure at cold idle. Motor has been pulled from project car. Sale does not include intake, carb, fuel pump, starter, generator, exhaust manifolds or clutch. Will sell fuel pump and clutch assembly for additional cost. Engine located at Annapolis, MD. Call or text Dave at 443.336.1001[/FONT]
