Chris Casny
A noise started to develop about 3 month ago, it started getting worst.
The noise always felt like it was coming from right next to me, so I figured it was the u-joint or that roller bearing, in the torque tube, close to the speedo gear.
A week and a half ago I took the whole rear axle, torque tube, etc apart to check out what could be wrong.
The u-joint and roller bearing looked worn so I replaced them.
Hoping that was it, no such luck.
I drove to a car show and back (400 miles) and I'm thinking the problem is in the rear axle.
I have not taken anything apart again yet, but could it most likely be worn bearings, or the ring and pinion not meshing together right???
BTW, the noise starts at around 55mph and stops when I let off the gas.
What could be my problem??? Bearings, bent axle, worn gears.
Expert help needed.
Thanks, Chris
Expert help needed.
Thanks, Chris
