1936 Ford Pickup
They are held in place by a set screw that is accessible from the door jam. They can be hard to get loose. It helps if you have the key so you can pull on the lock as well. If the set screw wont come out, they can be drilled, just don't go too deep.
The set screw has a slotted head not a socket head which adds to the fun, spray it
with KROIL etc if it is stubborn.
Charlie ny
