1936 ford conv sedan interior pictures
I have nothing for the rear seat or side panels. I can buy new springs but I have no idea what else I need. Does anyone have pictures of a car before or under restoration that would show the side panels or springs or any parts or wood framing ?
I think I should have spent the last 35 years building a time machine so I could go back to 1936 and pick up a new car at the showroom.
Building the time machine would have been easier and cheaper.
Here's some photos of an original trunk back conv sdn that might help. The wood and seat parts are basically the same for slant back and trunk back.
Rear seat cushion/springs sit directly on rear floor area. Rear seat back cushion/spring attaches to a wooden frame.
Sorry the drawing is in mm, this is the basic timber frame that houses the seat back springs.
The bracket down the lower corner is the hinge bracket and it located in the body, so that the rear seat can hinge open to access behind the seat.
I finished a 1936 Ford convertible sedan a couple of years ago and have an extra set of seat wood and a new springs that I did not use.
GEG
i can take pictures, it will take me a couple days, what details do you want pictures of, my car has original wood in the rear body
this is the original seat back
Thanks. It looks like there are metal posts at the top of the seat that must insert up into the rear woodwork . Do you have anything for the rear side panels?
