1936 Ford 3-window coupe
kwmpa
Williamsport
pa
Price
29,000
Well my interests are changing and im getting more into classic boats. I decided to put my 3-window project up for sale.
Here is the rundown...3-window coupe. fire wall has been recessed using a stockfirewall, new subrails and floorboards installed, quarter panels are from another coupe one is intalled on the car the other is with it, have a very nice 36 dash, waterfall, gauges are mint, have the crank out for the windshield, new knob for that, have new exterior door handles, new window cranks, all the window regulators anddoor latches are there. Top has been chopped 3" in front 3-1/2" in the rear. Has roll down rear window. I was going toset it up for a trunk but u have both sets of hinges so it could be trunk or rumble lid...have all patches to complete body. Nice set of rear fenders and tail light stands. Complete front end with very nice hood grill grill side panels, front fender supports, inner fenders and headlamp buckets, new stainless hood tim center hinge and grill center strip. have a 36 spare tire carrier(stamped steel), spare tire cover and trim ring complete with locking keys, set of NOS fox craft fender skirts. set of rechromed Appleton 112 spotlights. Roof has been filled with panel from walden speed shop,
Sitting on a 37 frame with a 37 fron axle front wish bones havebeen split, new king pins installed, have hydralic backing plates all around. have a factory 36 axle for under the rear with a cyclone quick change center section, have new getz ring and pinion and a complete set of bearings and gaskets to finish it out. 37 steering box with a 36 mast and column drop, have a crestliner accessory wheel and the steering shaftto go with it. brand new bob drake gas tank installed in frame. have modela rear crossmember and spring to install for quick change. original 39 ford pedal assembly, brand new master cylinder and wheel cylinders, rebuilt 39 trans. have a new front bumper as well
Engine is a 48 59AB flathead with a Scat 304ci stroker kit, schnider cam .395 lift 270 duration, Harrell heads, original edelbrock 4x2 intake topped by 4 new stromberg 97s, Harman Collins Magneto, new clutchand pressure plate. Engine is currently at machine shop being built and well be finished in the nest two weeks.
trade for a pre-1955 Chris Craft boat
im sure in forgetting something pm questions or for more pictures
If u read the ad I have all the sheet metal....just needs welded back together....we are talking about a 3 window with a 15000 motor and a 4000 quick change rear axle....
