Henry Hopper
Last night I took delivery of my new car..a 1936 Cabriolet.It fired straight up and ran great, however the lights don't work,the brake lights don't work and the horns don't work.I downloaded the diagrams from Vanpelt and have spent the day trying to get things sorted.
First off I checked the " fuse" I say fuse but it is a little oblong box that is sealed, I searched online and it appears to be a circuit breaker from a 40 Ford( I think), anyhow I have continuity through it..next I removed the switch from the bottom of the column and checked it out..cleaned it( although to be honest, it was spotless)I checked to see that the main supply wire in was working, ..it was.I opened up a headlight and a tail light to see if the bulbs may have been blown by someone trying a 12 volt jumper maybe but they seem fine.The wiring seems to be in great condition and not the usual brittle mess usually found....
One thing I did find is that the wires that seemed to be attatched to the central plunger part of the switch, the brass bit with the spring on it, we're both broken off...at first I thought this was the issue but according to my reading of the diagram it appears they are the horn wires?
I've come in from the garage ,stumped....anyone care to suggest what the problem might be..TIA.
