Henry Hopper
I've just driven my 36 properly since I got it and there is a whine coming from the rear of the distributor.At first I thought it was coming from the new Powergen alternator but after removing the v belt and using a listening stick it was found to be coming from the rear of the distributor.
I called a friend of mine and we talked about possible causes and one was to disconnect the vacuum line to the distributor from the manifold.I did this and the noise dissappeared...refitted it and the noise came back.
The noise sounds like a Pete Jackson gear drive...very noticeable at idle but seems quiter when revs increased...it sounds like a dry bearing kind of sound.
I've been looking up for any info on the web and ask, could the piston in the vacuum break make this noise if the leather pad was missing?ie,metal on metal?
