1936 Coupe
Richard in Anaheim CA
Hi everyone. I'm from the Model A group but need some help so I can help a widow complete her 36 coupe which is getting close.
We both live in Orange County CA if any of you are close
1. Tires.:I'm pretty sure I know this one 6.00X16. Do they use metal valve stems or rubber ?
2. Steering Wheel: I think the "banjo steering wheel is appropriate but are there other options? Rep'o's any good ?
3. Upholstery: Since LeBaron Bonney is now gone, who does she go to for
material or a kit ?
Thanks, I'll probably be coming back for a while on this
Richard
Anaheim CA
parrich1937@GMAIL.COM
Hello and welcome to this corner of the Barn.
Good luck with the project.
Yes, 6.00:16s all round. Not sure on stems, would suppose rubber.
Not sure which steering wheels are a bolt on. What does she have? Can that be used?
Someone else can chime in on the upholstery.
Again. best of luck for her and you as helper.
Mart.
The 600- 16 should have tubes,, the inside of the rims should be blasted for any sharp edges, possibly blast the whole wheel and paint,,I like liners with tubes but thats a matter of personal preference
1. 6.00x16 is correct. They do not have metal valve stems like the model A's
2. The banjo steering whell is also correct
3. Cartouche is the next best option since LeBarron Bonney is gone.
You did not mention in your request for info if the car is stock or is it modified?
The banjo type of steering wheel only came on the Delux cars, to my knowledge nobody re-pops the '36 banjo.
Does the car have the original wide 5 wheels, if so, you have to make sure they are 4.5" in lieu of the narrow standard type.
Yes, possibly some misinformation being passed here.
All the wide 5s were 4", except the V860s which were 3.5", but the 36 didn't get the V860 so should have the 4" wheels.
Mart.
I have had wide 5's ,5.5" and 6"wide.Quite rare.They were used on Large commercial like buses etc.They only had 4 scallop openings and not all the way around.The 36 std had 3.5" wide .Deluxe were 4" wide.
Classtique may well offer very good or better upholstery, but according to their website, they offer nothing after the Model A era, which does not extend into 1936, at least in North America.
Thanks guys. That should get me started. I haven't actually seen the car in many years.I'm just acting on a phone call that asked for help.
I'm familiar with the two upholstery places recommended. Need to give them a call.
Regarding tires I can unequivocally recommend Kelsey Tire, Goodyear Diamond treads for Model A's, Early V8 and the bias plys from the 60's. They are in Missouri, manufacturers and offer discounts for 50 and over quantity. You can mix sizes, black and white. Nice to deal with. It's surprising how fast you can reach that number when you put the word out.
Most likely, I'll Be Baaack
Glad to have you here. Looking forward to your project and future questions.
I have a pair of 5" wide fives for my coupe. I've been told they're off a commercial vehicle and pretty hard to find. I know guys that are building vintage race cars covet them...
This is from C&G. Someone else makes it, I can't remember who right now. I'm using one and it's good enough for me.
Richard, you know those V8,s are way better to travel in than an A
But the A is still good.
Hows things, say hullo to jeanie from Carol and Me.
Lawrie
I use tubes on my car/trucks around that yr. They share some stuff.
The place I used to mount/balance my tires and tubes had rubber gaskets around the valve stems and the wheel "rim". Think it was about a 1$ each. Reasonable and reusable for tube stems. Think big trucks were metal stems. Duct tape is an "alternative" to wheel liners, not the same as the the stem gaskets I mentioned.
I've apparently driven right past Kelsey Tires many times. In fact, I gotta go up there Monday. Maybe I can stop and fondle one of those 670-15 blackwalls.
