B barnfind Senior Member Apr 1, 2013 #1 Can someone measure a 36 coupe seat width at the top OD? Is a 37 wider? trying to determine what year this seat might be Attachments 1936FordCoupeSeat3.jpg 31.1 KB · Views: 29
deuce lover Well-known member Apr 1, 2013 #2 Does the back cushion lift up from the bottom? How about a side & back view.
Gary Tosel Well-known member Apr 1, 2013 #3 Based on the location and direction of the handle bottom center it is a 36 Ford seat. Without a back view or side view it is hard to tell.
41PICUP Senior Member Apr 2, 2013 #4 On my 36 it's 49 in outside to outside. Uppers corners are more rounded than your picture. Mine is a Fordor Last edited: Apr 2, 2013
B barnfind Senior Member Apr 2, 2013 #5 The seat back lifts from the bottom and swings on 2 hinges at the top. Metal bottom frame, wooden back and side frames. I don't have a pure side view picture - hope this helps. Is a 37/38 wider? the later bodies seems to be a bit wider thanks Attachments 1936FordCoupeSeat2.jpg 38.3 KB · Views: 20 1936FordCoupeSeat1.jpg 35.2 KB · Views: 22
deuce lover Well-known member Apr 2, 2013 #6 Its 36.Later bodies are not that much wider if at that.I've put 40 tudor seats in 35-36 tudors and they fit well.Holes in floor even line up.
