1936 5W Coupe Rear Window Drain Pan
Gav73
I need to remove the rear window drain pan from a fully assembled 1936 5W coupe. It has a full interior so I can only get to it through the trunk. I can see that it is mounted to the brackets that the trunk hinges mount to also. Are there any other mounting points or is it just the trunk hinge brackets?
Maybe this pic will help. Are you sure that the seatback (hinged at TOP) doesn't fold-up for access from the front, as seen in this pic? Coop
384282
I have a custom interior and have added a rear seat. I may be able to pull out the rear seat, however I'm not sure. I'll have a look tomorrow.
The drain pan is an integral piece of the welded in rear window panel.
The trunk hinge brackets are mounted to the back of the drain tray along with package shelf support brackets on the front.
