ROBERT JAM
Will 1935 wire wheels fit on an A
I sometimes do it twice a week.![]()
I'm putting them on a mechanical brake drum
How close are the P215/75/16 compared to the original Bias Ply 600-16 tires? Is there an "R" in the Costco nomenclature? (P215/75R/16?)Righto, '35 wheels are totally compatible with orig Model A drums. Be sure and use modern lug nuts, though, not Model A acorn style. The angle is shallower on the acorns and can loosen easily and you'll never know it till you hear a clunking and then the holes are wallowed out.
I especially like being able to run radials from Costco on the '35 wheels. I use P215/75x16.
The diameter is 28", close to orig so speedo stays same. Happy Motoring!
Should I be using modern lugs on my '32 18" rims as well jfreddie?
