1935 wheels
Prawbly
Hi all
I really like the 1935 wire wheel. My problem is I have a 36 with the wide fives. My question is will the 35 hubs fit on my 36 without problems. Thanks Pat
Actually, although the spindles for a 35 are longer, you can get by using 35 drums on 36 spindles by facing a bit off the back side of the castle nut that holds it all together. Works fine; I've been running that exact combo for years.
If there is enough room on the end of the spindle, how about getting the proper size die and cutting a couple of more threads?
