Dennisfly
I have the right passenger door inner panel removed to replace the window, which I am in the process of doing. I do not have a key that fits the door lock, so I figured I would just replace the whole lock with a vendor supplied one and it would have its own key. Problem is, I don't know how to remove the lock. The door latch has screws removed and is loose, but won't quite slide off the lock shaft due to the 90 degree bend in the back of the door. From what I can see, it looks like there might be a circlip that holds the lock in place but if I could manage to remove it, I would never get it back on with the latch in place.
How do I do this?
How do I do this?
