I am installing a 1935 rear axle in my 34 pickup. I will be shortening the stock 35 torque tube to fit. Two questions:
1. does anyone know right-off what is the OD of the 35 torque tube.(I am not near it right now to measure)
2. any tips on shortening the '35 drive shaft. Since I will have this done at a drive shaft shop I would think it would be a problem. Most reading i did was steering me away from shortening the tapered drive shaft.
any comments greatly appreciated
Thanks Frankie
Hello Frankie...A friend of mine (HEARD here on the 'Barn) and I tackled a project a while back that required shortening his '35 drive shaft and torque tube. We mixed, matched and combined factory Borg-Warner T5 5-speed parts to end-up with the shortest T5 transmission in existence. We then proceeded to making adapters, and shortened the '35 torque tube and drive shaft to bolt-up to the rear of the T5 transmission just like it bolted to the original '35 Ford 3-speed trans. If you're interested, you can read and look at pictures of the entire project by clicking on the link just below, but pay particular attention to POST #6 ("LET'S CUT 'N GLUE BOTH ENDS TOGETHER") for pictures and extensive details on shortening the d-shaft and t-tube.
https://www.fordbarn.com/forum/showthread.php?t=206955&highlight=T5+TORQUE+TUBE
I'm sorry, but I don't have the torque tube OD handy right now, but I do have several points for you to consider. First of all, having a drive shaft shop perform the surgery is a smart idea. If you can find an OLD shop like we did with an old GUY that has done this forever and knows some tricks, all the better!
Several things to consider. First of all, I'm not sure that you are aware that the '34 rear spring (and the rear crossmember that it fits into) are both CURVED forward at the outer ends when viewed from above. The '35 and later rear springs are STRAIGHT as viewed from above. This is something that will have to be seriously considered when figuring exactly where and how to locate the '35 rear end for purposes of determining how much to shorten the '35 t-tube and d-shaft. It is POSSIBLE (I can't remember spring lengths) that you may be able to mount the CURVED '34 spring onto the '35 rear assy.
One more consideration when determining lengths...the flat face on the banjo housing that the torque tube bolts to on the '35-48 banjo center housings is 1/2" farther forward from the axle center line than on the '34 banjo housing. Once you determine how you're going to mount the '35 rear end in the crossmember SPRING-WISE, and so that the tires/wheels are centered in the fender wheel opening, you need to lock rear end movement in a fashion such that the rear doesn't move while determining accurate dimensions. In the picture above, we simply used two pieces of electrical conduit flattened with a vise on each end. We drilled a hole on each end and bolted the rear of the conduit to two of the upper bolts on the banjo center housing, with the other ends bolting to some convenient holes on the chassis. This should hold the rear fairly steady at a pre-determined point under your chassis.
For measurement purposes, you must (of course) have the engine/trans mounted in their permanent location, with the torque tube receiving hardware/rear engine mount bolted to the trans. You must also have the Ford U-joint bolted to the transmission output shaft. DO NOT assume that the amount that you cut out of the drive shaft is automatically going to be the same amount that needs to come out of the torque tube. MEASURE EACH SEPARATELY, at the appropriate time!
After a couple of false starts in trying to determine EXACTLY what to measure for shortening, we finally realized that the critical measurement is going to be between the center line of the hole that the locking pin goes through the splined pinion shaft at the rear, and the CENTER of the speedometer gear on the transmission end. The speedo gear sits at a pre-determined location on the drive shaft that CENTERS the gear in the speedometer drive hole in the torque tube. NOTE: The info you received about NOT cutting EITHER the tapered d-shaft at the front, nor the tapered torque tube at the front is EXCELLENT advice. Make your cuts at the rear of each.
Place the drive shaft into the torque tube. Assemble the front bearing, speedometer gear and snap ring onto the d-shaft at front end. The speedo gear should line-up centered in the speedo drive hole. Securely bolt the two clam shell halves around the t-tube bell (after stabbing the drive shaft splines into the U-joint). Once the front of the t-tube and d-shaft are secured to the trans, carefully swing the rear end of the t-tube next to or above the rear torque tube flange surface on the banjo housing. Mark the torque tube precisely in line with the face of the flange on the banjo housing. This mark will indicate the TOTAL length of your modified torque tube (including the tube's rear flange) once re-welded.
Now, before you do anything else, measure precisely the distance between the BANJO t-tube flange face and the MIDDLE of the speedo gear. Now, carefully slide the torque tube toward the rear, leaving the drive shaft inserted into the U-joint. With the t-tube out of the way, carefully slide the d-shaft's aft end as close as you can next to the rear end splined pinion. To make sure everything is the same as before, measure between the rear banjo's torque tube flange face and the center of the speedo gear. Slide the d-shaft fore or aft in the U-joint until your measurement matches the measurement you made in the first sentence of this paragraph. Once the measurement matches your initial measurement, and with the d-shaft as close to the pinion as possible, mark the drive shaft in line with the center of the lock pin hole in the splined pinion. This is the distance that must match (speedo gear to lock pin hole) when your drive shaft has been cut and re-welded. It appears, from the picture above, that the coupler continues rearward on the splines a little more than another inch or so...just so that it's length does not exceed the total length of the pinion splines, as this part of the shaft remains fixed to the pinion and does not slide as the rear articulates up and down. Hope this helps you. Any more questions, just ask, or PM me...I'll try to answer. DD
