TDS
Hi
I got a 1935 221 cui Ford V8 flathead.
The engine and ignition is stock. Exhaust is not.
I have recently replaced my carb. The old one was a Solex whit a choke issue.
They used the Solex paai 30 on Ford V8's in Denmark.
I have rebuild and mounted a Ford 94 carb.
The Ford carb has given me some issues as the vacuum suddenly was way off.
I therefore gave the dist an inspection and cleaned it.
Some one had mounted a 1937 dist, before my time, but i put it back on.
Today I got hand on a 1935 dist that I awaiting parts for. I want to mount that instead.
When cleaning the 1937 dist I was very careful marking the point timing and install the dist it the same way.
I also replaced 2 bad sparkplugs.
I had to tighten the vacuum plunger to max to get rid of pinging.
After this it actually ran great until this afternoon.
Suddenly after 15 miles I got a weird tapping noise. I was like a rhythm like at tap followed with tapping getting lower and lower. It repeated for the next 4 miles. Idle was okay and I got the car home.
About 2 miles before home the tapping cleared away.
Now I hear some tapping/knocking from the engine front when I deescalate but Im actually not sure if its related.
I use MMO in the gas.
I haven’t messed around with anything but the carb and the dist.
I need some guidance to locate what could be the issue.
Thanks
Thanks
