1935 pickup radiator still looking
jdjj
Anybody have info on measurements for 1935 pickup radiator. Seen lots of pics but none with measurements. Need over all height and width. Thanks
Here's the Ford Engineering drawing for the Model 51 truck radiator. The only difference for a pickup is the bottom radiator hose fittings slant up instead of the ones in the drawing which point downward.
thanks for the pic just couldnt read the numbers made a print and used magnifying glass just couldnt see. Would you mind giving me the height from from top of tank to bottom and width with out side brackets. Thanks again!
Top of radiator to bottom of feet is 29.34"
Width between holes in feet is 21" and width of core is 19.75"
