1935 Pickup Fender Support
CA Victoria
My pickup didn’t come with the front fender supports. I have collected a couple of different styles........The two longer supports in the photo are closest to fitting but fall short by about 1/2” of making the distance between the frame and the inner fender.
If these are the correct ones I will put them in the stretcher.
What does the brace with the carriage bolt fit?
Here's a photo of the secondary front fender supports for the 1936 Pickup, that I'm working on. From end-to-end, the measure about 10-3/4". The should be the same as the 1935 Ford.
