Although I read 2 similar threads, I'm still stuck with 2 non-working '35 horns so here goes. Background:
1. they worked poorly but worked a few months ago but then stopped and didn't respond to adjustments with the screw adjuster, and now not at all.
2. They are repro horns, judging by prior posts and a picture in the Forum; not sure where/when purchased. I'm assuming the horn itself grounds the horn?
3. I took apart both horns and cleaned what appeared to be the points then reassembled each so again the adjusting screw is directly above.
4. both horns have 6.3 volts on BOTH wires attached to each horn. Each has a yellow and a blue/yellow wire attached to the horn. the yellow is also attached to the ignition starter switch (hot side); the return wire for each goes into the light switch basket. I've taken that apart and cleaned each. The basket was making a snug fit. The bail wire came over snug seemed to fit correctly. W. volt meter, no volts showing when touching the horn rod, etc. but the lights work.
5. Some earlier posts talk about using a relay but others disagree. I don't think I have a relay in the circuit. And in any even it all worked earlier.
6. Wife pushing horn button has no effect on voltage reading
7. pushing the horn button "feels" like there's a working spring.
Any thoughts? Thanks, Ron
