1935 Ford V8 Locking Gas caps
Neither the 1935 nor the 1936 gas caps were originally vented. The vented filler neck on the 1936 model took care of the venting. The small tube inside the filler neck was structured to vent and if needed to release overfilled tanks below the topside of the fender. Some with better results than others. The vented cap was for later model Fords.
Geg
I believe that most if not all gas tank filler necks from 1936 thru early 1939 were vented allowing the use of a non-vented gas cap. During the 1939 model year the filler neck venting was removed necessitating the need for a vented gas cap.
The drawings below show the evolution of the Ford locking gas cap from 4/8/35 thru 3/18/39 when venting was added to the cap.
Here's a Stant drawing indicating when some of their changes were made to the locking gas cap.
