Typical advice is not to run more than a 4# cap on the old radiators unless the tanks have been reinforced to handle the extra pressure. I put a 4# on my '38 and could hear the upper tank pop when the tank oil canned, and then hear it again when it cooled off. I took the pressure cap off.
I think the only reason a pressure cap will help it to run cooler is it might prevent some coolant loss from overflow and retain more coolant in the radiator.[/QUOT
Under a pressurized system, it takes a higher temperature to make water boil.
MIKE(mikeburch)
MIKE(mikeburch)
It also helps to squeeze coolant into areas that are normally air pockets in the cooling system.
The boiling point has nothing to do with this problem An old Ford should never get to 212 degrees so where does this boiling point factor come in??. The purpose of the pressure cap or Skips 3 lb valve is to close the over flow tube so water can be forced through the radiator tubes which act as a restriction. The cap or valve is also a safety device that opens from pressure to protect people and the system. G.M.
The boiling point has nothing to do with this problem An old Ford should never get to 212 degrees so where does this boiling point factor come in??. The purpose of the pressure cap or Skips 3 lb valve is to close the over flow tube so water can be forced through the radiator tubes which act as a restriction. The cap or valve is also a safety device that opens from pressure to protect people and the system. G.M.[/QUOT
You say, "an old Ford should never get to 212 degrees". I have seen several old Fords, over 212 degrees. S**t happens !
Be sure to clean out Skip's overflow valves, ever so often. If you have any crud in your cooling system, it will eventually get into the valve and plug it up. Be sure to keep it clean.
MIKE(mikeburch)
