You can also leave the Grill in position ,pull the pumps and Generator then fit a 2' piece or so of rubber heater hose over the generator stud ,sling it at the top around the tank ,lean the radiator back. Disconnect the other bits as TJ , & CA say then with a engine hoist lift it . ( MDF or ply wood also is good protector )
