1935 ford pickup
gillis
Is there enyone ho has a picture of the large front fender brace ( how it's mounted on the frame ) and the same with the fotstep (i've mounted my body on a 1939 frame and the holes to the front inner fender and the front brace and the fotstep is not fitting right :-( so if someone has a drawing that shows were the holes should be it would help me alot thanks /Gillis
I told him to send me a direct email and I would send him a picture of how the large front fender brace mounts, but I have not heard back from him. I'll even send him a picture of the "fotstep" if he will translate. LOL
35 40 frames are the same but small differences mean you have to re -drill some points for fender braces , running boards & the like.
Recommend you take your time , use some good long tapered punches for aligning
and be prepared to re drill or slot a few holes. enjoy. Rascal
Gillis, here is some detail on the front fender bracket mounting holes.
Don Rogers
