There is also a single screw that is used to attach the panel -- almost right in the middle of the panel. There is a bracket that comes from the bottom of the bed frame. Three holes along the top edge, and the screw in the side.
Hope this helps.
Hope this helps.
There is also a machine screw/bolt that goes through the front of the rear fender and the filler panel, Filler panel needs to be attached to the fender before the fender is attached to the bed and bed to frame.
