Somewhat off topic, but that helpful diagram that Don posted is slightly different for '35-'36 phaetons and roadsters. The bolts attaching the housing to the dash insert from the bottom, not from the top and the holes in the housing are bored out to eliminate the threads. The part on the inside of the dash (18) came in two forms, the first being a hefty steel block with raised ends to clear the bottom of the speedometer and the second a steel stamping folded over to be of sufficient thickness to be threaded for the attaching bolts like the steel block. You can always tell a housing that was originally used on a phaeton or roadster as it lacks threads in the two attaching holes at the top.
