Hello all!
I'm a newbie here, and would like to thank you for the opportunity to able to join your Community. I live in Utah and am building a 1935 Ford 5 Window (as you can tell from my Username)-I am getting closer, and am hoping you can answer a few questions I am having as I have never built an older Car like this, and there doesn't seem to be a good "blow-up" view of how the parts go together-some times I feel like I'm putting togehter a 1000 piece jigsaw puzzle without the Instructions.
Anyway, my first question has to do with the front Fender Braces-I am in the middle of metalfinishing a set of front Fenders I bought, and noticed that there is a bolt hole in the middle of the fender lip-I have purchased two sets of what I thought were standard Fender Braces/Headlight Supports and they do not seem to have a provision for whatever type of brace (?) might have been there.
I used your fabulous Search function, and found this Thread:
http://www.fordbarn.com/forum/showthread.php?t=7108&highlight=1935+ford+front+fender+brace
So, it appears that maybe I have a set of early '35 Fenders-how important are these outer Braces? They do kind of look like a good idea, because as far as I can tell the inner Braces/Headlight Supports are the only Braces to hold the front Fender from there forward-correct?
I have been buying parts for this build for 7 Years and have never seen a set of the outer braces, so they must be like hen's teeth-I suppose I could make some-just how important are they?
The next question is: where the Headlight stand/Headlight bolts through there are four holes-I understand three of them (one large one for the Headlight, two small ones for the Headlight Stand, and then there is one that is offset to the side-what is it's purpose, as it appears that the Headlight harness goes throug the Headlight mounting bolt-I can't seem to find a picture where that hold is being used.
Thank you in advance for your knowledge/contribution to this old newbie's edumacation!
