Henry Ford IV
It did start about 5 times. Then, the next day it didn't start. i replaced the coil with a known good one from Third Gen. I got a new condenser from Third Gen. Here is my question. Do you think it won't start because I have no ground at the engine? When I touch the coil wire with a multimeter and then put the other end of the multimeter anywhere on the engine or frame there is no voltage. If I get a long wire and touch the coil wire and starter switch on the floor in the cabin I get 6 volts.
