1935 Ford Coupe
joanne1432
S. Ozone Park
NY
I have a 1935 Ford coupe, 5 window with rumble seat, trying to confirm either way if there is a water troff to catch water that comes off of the deck lid. Can anyone help me out with this? Also what does it look like? Jim
Jim-
Sorry, no trough! Ford just let the water run off the lid onto the floor pan where a couple of small drain holes would allow the water to drain out. Basically, it was a "Hope everything would evaporate" system. This probably explains why so many original Ford rumble seat cars have rotted rear pans.
Tom
joanne1432 ........................
I, too, found the original (hope everything evaporates) system flawed. I took a round punch and made several drain holes, in the lowest points, in my rear pan. It might not be original, but I like my idea better !
MIKE :)
I have original parts that direct the water out of the car, this may have been a running change.( pun intended) 541-582-8966
I have an early 1935 trunk model coupe which didn't originally have any drainage system, however later model '35 & '36 trunk models apparently did. Picture below, which I saved from somewhere, shows the location of one of the corner drain pipes on a '35. The rubber hoses which take the water from there through the floorpan were part #48-725854 and are sold by several suppliers. Haven't had any experience with rumble seat models, but guessing they didn't have this system, as others have said, because there is not a "trough" across the bottom of the opening.
EDIT NOTE: Just noticed this is an OLD post and he's likely got it figured out by now!!
