- City
- Santa Cruz
- State
- CA
- Price
- 28k obo
1935 Ford 5-Window Coupe...not as stock as some of you would like
Body
-Original 1935 Ford 5W coupe, rust-free
-All body work finished with new patch panels
-New recessed firewall
-Frenched and angled 1939 Ford taillights
-New windshield and polished frame, opens and closes
-Rear window rolls up and down
-New hood and grille trim
-New quarter glass and seals
-No door glass, but I do have the regulators
-New wood bows in top
-Newly covered runningboards
-New front and rear bumpers and guards, with shorty brackets in rear
Interior
-New complete floor
-Polished steering column and brushed aluminum steering wheel
-Stewart Warner gauges...speedometer, oil pressure, and water temperature
-Minivan bench seat...fits perfectly, just choose your upholstery
-Working glove box
Drivetrain
-Chevrolet 350cid smallblock, 4-bolt main, almost new with 1000 miles on full rebuild
-All new components, including Holley 4-barrel carburetor, Edelbrock intake, water pump, alternator
-HEI distributor
-Blockhugger headers and full exhaust with glasspacks and pencil tips
-New Walker radiator
-Finned valve covers, air cleaner, and oil pan
-High-torque mini-starter
-TH350 transmission
-Finned pan
-New filter and recently gone-through
-Lokar kickdown cable
-Lokar traditional-style swan-neck shifter
-Trans-cooler
-1956 Oldsmobile rearend
Frame, Suspension, Steering, & Brakes
-New Speedway frame, fully boxed with tubular center section and setup for IFS
-Mustang II rack and pinion steering
-Independent front suspension and disc brakes
-Four-link rear suspension with coilovers and panhard bar
-Rear drum brakes with new shoes and cylinders
-Dual power master cylinder, all new lines and RPV's
Wheels & Tires
-15" smoothie-style wheels
-Ford center cap and ribbed trim ring
-Rear tires-Firestone Deluxe Champion 7.00/15(4" whitewall), bias-ply
-Front tires-Firestone Deluxe Champion 5.60/15(2.75" whitewall), bias-ply
This car was pretty rough when I dragged it home, and even rougher when I got the body back from the media blaster! After the blasting removed the 10 coats of paint and we could see what we were dealing with, I had the body professionally done with brand new floors and firewall, and all rust removed and patch panels installed. All the gaps are nice, and the car looks good with or without the hood. It's all bodyworked and primed, you pick the color and there you go. While the body was getting worked, I did everything else with all new parts...drivetrain, fuel lines, brakes, steering, and suspension. I really spared no expense, and wanted something dependable that I didn't worry about my girlfriend driving. The car's solid, and has been my daily driver all spring. It starts right up, the TH350 shifts smooth through all gears, and it stops on a dime. The exhaust sounds great. The doors open and close smoothly, the lights work(high and low beams), and the gauges work and light up(and dim). I put a Painless wiring harness in it...it wasn't totally painless, but not too bad! The battery is in the trunk, so I ran big 2/0 gauge cables to the starter and the engine block...as well as a ground from the engine to the frame, and body to frame. There are no starting or charging issues with this car. There's a new fuel cell in the trunk. I want to get back into a hot rod...an AV8 roadster or coupe on a '32 frame, maybe a flathead or a 6-deuce nailhead. I change cars like I change underwear. Anyway, that's why I'm hesitantly selling the '35. Clean title and current tags, as well as the old-style, 1935 California license plate that has the same number as the current plates. I'm more than happy to assist any shipper you choose, and can store the car in my garage for a little while if needed. Give me a call or shoot me a message if you have any questions.
More pictures and details:
http://adambarton.com/Buy_me!.html
Here's a little movie I made with some recent pictures and older movie clips of the car from it's first drive...before body work, exhaust, etc:
http://www.youtube.com/watch?v=l7UIdez2eQw
Or you can search under my username, av8flathead, on Youtube:
http://www.youtube.com/results?searc...8flathead&aq=f
$28,000 or best offer...anything reasonable, really...or trade for a 1932 Ford roadster, 3w, or 5w. Would also trade for a 1928-1931 Ford roadster or coupe on a 1932 Ford frame. The more traditional, the better. No bikes, or cars of any other year. Thanks.
Adam
408-821-1613
Body
Interior
-New complete floor
-Working glove box
Drivetrain
-HEI distributor
-TH350 transmission
-Finned pan
-Trans-cooler
Wheels & Tires
Adam
408-821-1613
