1935 Ford 5 Window Coupe rolling chassis
ken-r-mer
Seven Hills
Ohio
Price
$24,000
1935 Ford 5 Window Coupe (Model 48), a two-tone blue body / grey fenders matching the interior and rumble seat. Side engine compartment panels and hood are included but not shown in the pics. A Southern California hot rod up until late Spring of 2015. Vehicle is a rolling chassis minus the flathead V-8, T-5 transmission, and drive shaft, as they are in the process of being rebuilt for a new hotrod project. Built in 2010. Henry Ford steel body, so rust free, coming from a CA dry environment. Stock frame, with "Posie" rear suspension (Ford 8" w/ 3.50 ratio, leaf springs, shocks and anti sway bar) and a Mustang II front end with chrome coils and shocks. The vehicle is setup with a TBI EFI fuel system with Mega Squirt II software on a laptop that handled 2 - 1988 Ford Escort TBI's (a custom 2010 EFI setup) that were on the Flathead V-8 ( minimal work is needed for a newer up to date EFI setup), Southern Air AC, and a reinforced trans mount for a modern transmission (stick or automatic). In 2010, a CA appraisal (comes with sale) had the vehicle valued at $44,000. The vehicle just needs either a Chevy 350 or a Ford 302 V8, including a manual or automatic transmission, radiator, correct engine mounts and a driveshaft for a nice cruiser. If you want to install your own flathead, I'll include the radiator and intake manifold with the 2 -1988 Ford Escort TBI's that it was running with, so only a T-5 trans or a Ford C4 and a drive shaft is needed to be up and running. With the current stock frame, this vehicle is meant as a cruiser and NOT as a muscle machine. A muscle machine would require a new high performance frame.
In 4 summers of car shows, 9 trophies
$24,000 firm. No trades.
Call Ken at 216-524-2006
  • driver's 3:4 front.jpg
  • driver's 3:4 rear low.jpg
  • passenger's 3:4 rear low.jpg
  • passenger's side 7:8 front.jpg
