1935 Deck Lid Handle Lock Removal
Im hoping that someone here can explain to me how to remove the lock tumbler, without a key.
I am hoping to re-key the original tumbler to fit a key that i have.
Any help would be greatly appreciated.
Thank you
You need to have the key or the master keys. There is a spring loaded button down in that hole. The key inserted then turned with the slot up will enable you to push that button down then you can pull the lock cyl out. There is a code stamped on the side of that lock cyl.32Phil a member here is our go to guy ,call him..845-551-5132
