I drive my 35 very little so every few years I will drain the gas and put about five gallons back, this time I noticed some small (what appears to be ) pieces of metal. I do not have any leaks have not noticed any odor, is it ok to use this tank or should I change. The car has original sender( which does not work) can this tank be fixed? Noticed that 35's are usually replaced with 36's that have a different outlet and I've been reading the stories about the filler neck removal
