Dave/Green Bay
Does anyone have a picture of the placement of the control valve that mounts on the top of firewall on a 1935 ford? I have the instruction but pictures are very bad. Thanks Dave/Green Bay
The 90 I had setting in my tool box for the past 30+ years. I think it came off an aircraft tachometer or something of that sort. I have seen them on the internet. The roadster dash is approximately 1" closer to the firewall than the other models so I had mod the shifter lever in addition to using the 90. If you decide to do the same with the speedo changer, only tighten the mounting clamp so it just barely tightens. If you over tighten the clamp it will bind and break your speedo cable. I learned the hard way on that one.
Sent from my iPad using Tapatalk
The vacuum hoses hook to the main vacuum lines to the rear end. I've included an additional picture that should help.
