Jakno Senior Member Apr 10, 2015 #1 I need to replace the wooden 2pc rail inserts between the cab and frame on a 35 pickup. Is there a supplier that you have used with good results ?. Thanks Attachments 35 cab.jpg 68.8 KB · Views: 21
Zimmco Senior Member Apr 10, 2015 #3 Mack Hils has them also. They're actually glued up as one piece on each side. Nacewicz has the correct fasteners.
