AzBob
My 1934 engine had water in the oil and upon disassembly, I found huge crack repairs on both banks with a bolt running from outside the block to the valve galley. Also, deep rust pits in No. 4 cylinder and a hairline crack in No. 1 cyl.
I have located what appears to be a clean 1935 block recently disassembled that appears to be in great shape. Only crack found is between one of the stud holes and a water passage. Comes with crank, pistons etc. Std. bore with no ridge at top of cylinders.
My question is can I use the following parts from my '34 engine on the '35 ventilated engine? (Cylinder heads, intake manifold, oil pan etc.) Anything else I should be aware of?
Photo of crack and bolt head on RH bank.
