jkflathead
Does anyone know the shock arm lengths, front and rear for 1935 -1939 Fords? Thank you. John
No period Ford shock arm is only 4" long; perhaps you are thinking of the links between the end of the arm and the axle.
39s are 4"
No, the shock links are NOT 4" on a '39. They are 3" at all four corners.
The 4" links were first placed on '40 Fords, front only and then only the vehicles equipped with the stabilizer bar.
With respect, I disagree with your statement. 4” shock links were introduced on the 1937 Ford (NOT the ‘40) for the front only. The 4” link carries part number 78-18055 A1 or A2. This was carried through 1939 on the front as well, with the only possible change being an early ‘39 introduction of the Marsden nut for attaching a changed shorter stud on the link versus the 5/16 fine thread and a lock washer attaching hardware on the earlier longer link. This is all documented in both the ‘37 and ‘38/9 books.
If you believe the Green Book, the “Shock Absorber Link Chart” on page 325 indicates 3” shock links (48-18055) on both the front and rear (NOT a 4”) on 1940 Fords with a 4” link being used on 60hp cars.
. . . The 4" link was placed into service as there was an interference created with the addition of the "new" sway bar in 1940.
