1934 wheel studs
Synchro909
Are these wheel studs the same as the one used in Model As? I have a ruined stud on one drum and I don't like the idea of driving on it like that. I can get Model A studs but not '34 ones if they ae different.
CW Moss lists same for studs for 1928-31 front and 1932-35 front and rear. Then a different one for 1936-48. So the Model A front stud should work with 1932-35.
They also have a different part # for front and rear for the 1928-31 Model A.
Hope that helps.
Hope that helps.
If your conclusion is correct, that could be my savior. THANKS.
This seems to show they are the same:
picture.php
Arnold, I wouldn't use the 33/34 brakes on your A.
cast iron A drums are available easy as, good useable 33/34 stuff is NOT.
You can make your a brakes as good as ,just takes time, Like 2 weeks on the one in my shop.
Lawrie
