1934 vacuum control valve columbia
mike37cdn
hi i have a 1934 roaster with a columbia axle i am looking for the vacuum control valve that is worked by the clutch or if someone has something that will work thanks mike
John Connelly at Columbia Two Speed Axle in California will have it for u. Reproduction but good.
Contact John at Columbia Two Speed Parts, he has everything you need. If the 34 Roadster is the same as the 36 Roadster you will have to shorten the rod for the selector valve mounted on the dash as the dash is approximately 1" closer to the firewall than the closed cars. http://www.columbiatwospeedparts.com/ Hope this helps.
Sent from my iPad using Tapatalk
well you can only buy the hole thing witch is 1300 but you get all the vacuum parts i only need the valve have rebuilt the rest of the vacuum parts can only buy the 35-36 one from john
You might want to call and see, John has worked with me in the past and sold me only the parts I have needed. You might also be able to use the 35/36 pedal valve if you are willing to run something not 100% original. I would check for compatibility as it's not a cheap part.
i looked at the 35-36 one i said it would pay for the 34 valve but john would not sell just the valve so looking for something else or will go with a 35 or do i need the valve just bypass it and just use the control valve on the dash
Good luck in your quest.
