1934 V8 slipped timing gear
hudson1948
Has anyone ever seen one of these press on gears slip. Was on a road test running great no problems. All of a sudden it lost all its power. 75lb of compression accross the board and 14 inches of vacuum at idle. Freshly rebuilt has about 30 miles on it.
Yes, I once encountered that....now on all my builds I 'scotch key' the gear in place to prevent it happening. To fit a scotch key, drill and tap a hole somewhere around the seam where the two components fit, and screw in a grubscrew.
When I was 16 I had a 34 with a low mileage stock engine strip the
fiber teeth of the timing gear. I had to remove the grill and radiator
and chisel the aluminum hub off the front of the cam. If I remember
the cam had a slight knurl that had a slight twist in the knurl so the
new gear twisted about a 1/4" as it went on. I was lucky and got the
timing marks lined up and it ran good. This was a sedan with 6,000
miles that was put up on jack stands during world war II. I never
liked sedans and sold it. G.M.
