1934 upper radiator hoses
epw1949
I am putting a 59 type engine in a 34 car using the 34 radiator.i know that several thousand people have done this before.my question is,does any one make a upper radiator hose to fit,or what has others done to make this plumbing look decent? Any and all help will be greatly appreciated. Thanks e.p.w.
Do you already have the radiator? When I had my radiator made I had them bring the inlets straight back so that is easier to plumb to the heads.
Hi I used a Carquest hose #23040 its made by Gates. It is an S shaped hose I cut to fit and worked out great. send me your E-mail and I can send you a picture. Bob
I can add a couple.
You can take a stock 37 hose, cut it in the center, turn one end and insert a pipe between the two cut ends and it fits like it was made for it.
