All of a sudden my stock '34 won't start. It usually starts right up. It appears that I have no spark at the plugs but I have 2.8 volts at the coil with the resistor and 5.5 volts when I bypass the resistor. One by one I have changed the coil, condenser, distributor, cutout, by passed the resistor and replaced the ignition switch. The only real clue is when I hit the starter the ampmeter swings rapidly from 20+ to 20-.
What would cause this?
Grateful for all suggestions.
