1934 standard roadster?
Elvis100
I’m building a 1934 standard roadster around a dash. I was already building the car when I picked up the standard dash. I’m sure it is from one of the 1000 pheaton’s and not one of the 8 roadsters. Looking for information on what was chrome on a standard roadster? Grill? Stansions? Top irons? Windshield frame? Already planning on a trunk and not a rumble.
With respect, what is the source of the '34 open car production figures that you cite? According to Ford's production records, no '34 model standard phaetons or roadsters were produced in the U.S. for domestic sale. A very limited number of '34 standard phaetons (not 1,000) were manufactured in whole or part in the U.S. for export (I once had one from South America).
If they existed, they would replicate the '33 standard roadsters in the details you've listed. The windshield frame, posts, top irons, and top bows would all be painted black. The instrument panel would be painted maroon. The grille was the same as on all '34 passenger cars, namely chrome plated.
The 33 Standard roadster had a woodgrain dash from May 1933 onwards. The vacuum line on the left windscreen post and left mounted horn (one only) were also painted black, one tail light and rear window frame with a black exterior/gray interior and brown painted rear mirror brackets were other Standard roadster features. Rare cars, good luck.
I got this from another thread
David, I have a 34 phaeton that has no cowl lights. The cowl does have a reinforcement where the lights would go but has never been drilled. I imported it out of Ontario Canada a few years ago. It has a Canadian vin # and interestingly it has battery openings in both sides of the floor so it could have been assembled either right or left hand drive. I would think it would be a standard and for possible export from Canada. It has all of the US body features, not the cut down Australian sides
Both the production numbers in #4 above and the U.S. domestic production numbers that I cite in #2 (which are found in the DeAngelis/Francis book,"The Early Ford V8 As Henry Built It, A Production Facts Book 1932-38") are derived from the same Ford documents, namely the "Monthly Assembly Record" of Ford's Production Department. Accordingly, they can be considered as the one and only accurate record on the subject. However, they are calendar year figures, not model year figures and they do not distinguish between '33 model 40s and 1934 model 40s.
As a result since we know that the U.S. public introduction day of the 1934 models was December 9, 1933 (likely the same date in Canada as well) it follows that a fair number of '34s are included in the 1933 calendar year production figures. It gets messier when you look at the details showing the production by assembly plant as we know with certainty that Job #1 for the '34 models was not the same for all of the U.S. assembly plants. Nor do the available records show what the Job #1 date was in 1933 in Canada for the '34s. Further compounding the mystery is the fact that while the Dearborn Production Department data includes the production figures outside of the U.S., including Canada, there is one glaring exception as absent are the production figures of Ford of Canada's largest wholly-owned subsidiary, Ford of Australia, which produced a fair number of roadsters and phaetons with their unique body construction in both 1933, 1934, and on into early 1935 given that during that period of time Australian Job #1 dates lagged behind those of the U.S. and Canada by about four months.
So, leaving aside the question of the production figures for the unique Australian '33-'34 open cars, what little we can conclude is that unless some heretofore undiscovered documentation turns up in the Ford U.S. and Ford of Canada archives that delineates the distinction between '33 and '34 models' production (which is highly unlikely given the amount of time that I have already spent in both those archives trying to find such a delineation without success), we will never know just how many of any of the various body types produced were '33s or '34s as all we have are calendar year figures.
uncle buck,
I imported a fair number of '33 and '34 roadsters and phaetons from South America (primarily from Argentina) back in the mid-1970s and again in the early 1990s. All of them were of U.S. manufacturing origin and with the exception of those from Brazil, always a LHD country, unlike Argentina, Paraguay, and Uruguay which switched from RHD to LHD in 1948, the floor pans had both battery openings in their floor pans, which of course was necessary for RHD vehicles as the battery was located on the left side in four-cylinder cars and on the right side for V8 cars because of the different routing of the exhaust system (always on the right side in fours, on the left in RHD V8s, and on the right for LHD V8s). That your Canadian phaeton has both battery location holes is consistent with that practice since the majority of Ford of Canada exports were to RHD Commonwealth countries.
mvee33,
The only way to confirm whether or not the late '33 wood-grained dash was carried over to '34 standard open cars or they were painted maroon like the rest of the '34 standard models would be to find the relevant engineering releases at the Benson Ford Research Center to provide the answer. I'll put it on my to-do list, but since the BFRC remains closed to the public, who knows when I'll be able to do so.
DavidG, While I don't consider myself a '32 = '34 guy, I read each and every one of your posts if for no other reason, just to learn new things.
I'd like to thank you for sharing your knowledge and experience with us mere mortals.
Each time I start to think I know quite a bit about '40 Fords, I am reminded and humbled by your knowledge of the '32 - '34s.
Quite sincerely,
Mike
Quite sincerely,
Mike
X2 but for me 1932 - to at least 37(from post read on here!!!)......I can only hope to achieve a mere fraction of his knowledge!!!
BY the way that includes your abilities and knowledge to KUBE....IF i can achieve a mere fraction.....IF???? Incredible, both of you!!!!
X3, Thanks David for taking the time to thoroughly explain where the numbers published in books come from and where there are gaps or uncertainty. I am not a '32 guy, but I always look forward to reading your posts along with Don Rogers and Kube's.
x4, I learned now that my RHD 34 Tudor that came from Argentina and has written on several parts "Industria Argentina" was not rebuild with a RH steering but probably started life with this version.
Thank you
Harty
I remember some years ago seeing a 4 cyl red std 33or 34 roadster at Stone Mountain's museum shop in GA.
I am very thankful to have David's input here. His wealth of knowledge, dedication, kindness, and willingness to share is very much appreciated!
Quite sincerely,
Mike
Ditto for me and I'm a "fatty" 46 -48 guy and know those cars inside out. Very interesting about the Battery openings, a mate of mine had a 33 4 door hotrod years ago and I remember we built and carpeted raised cover to accomodate a tall 12v battery that was in the left front floor ( RHD as it came from FOMOCOs NZ plant).
GB
