1934 rear axle parts interchange
roadster36
I finally blew the rear-end apart in my '34 roadster to replace the inner seals and check out the bearings, etc. It turns out that the carrier has a crack all the way around below the carrier bearing. What carriers interchange with '34' s ? Thank you- Dennis
The two-piece differential case is one of the few rear axle parts that's the same from late 32 to 48.
I believe late 32, 33&34 center sections are the same width. The center sections for 35 thru 48 are the same. The axle housings change in both length and spring mounting through the later years.
